Home › Forum › Ask A Member › Johnson A 35
  • #2779
    Rob
      I picked up a Johnson A 35 today at the 50th Anniversary meet in Winter Haven Florida. πŸ˜€ πŸ˜€ πŸ˜€ πŸ˜€
      It’s very cool, but…
      It’s stuck… πŸ˜•
      So I filled the cylinders with penetrating oil, and put it in a corner for ‘later’.
      I know a bunch of you have been down this road before, so I would love some suggestions/advise on how to get her apart.
      And then, once I get her apart, what do I do about the guts (rings, pistons, cylinders, etc) that are probably damaged from the seizure/rust?
      Thanks everyone!
      Rob
      Rob
      #25603
      b-morrison
        I’ve used 50/50 transmission fluid and lacquer thinners and let it set hours, days but usually works . parts may just need cleaning….depends. goodluck.
        #25683
        Rob
          Thanks B.Morrison! I’ll definitely try the 50/50 mix!
          I guess my question goes a little further than that. I got all the screws out of the cylinders but the cylinders aren’t budging at all. I guess I am asking about how I should I go about ‘persuading’ the cylinders off of the pistons/rings. I tried heating the cylinder with propane which didn’t help at all; the cylinders didn’t move at all. Then, I used a block of wood and a hammer and tried tapping on the side of the cylinders but that didn’t accomplish anything. I feel that just blatantly beating on this thing with a hammer and a block of wood is counter productive. So I guess what I am asking is; what technique I should employ to get this motor apart? I don’t mind taking it slow, I just want to move in the right direction without breaking more than I have to. Any suggestions or advise would be appreciated πŸ™‚
          Thanks!
          Rob
          Rob
          #25687
          david-bartlett
            Rob,
            One of the members here, Lloyd Lautner, suggests using a large volume of hot water. Either pour it over the outside, or submerge the cylinder in a big pot. The idea is that with a large volume of water, you get more rapid heat transfer/expansion than with a small source like a torch, etc.
            Then give it a couple taps with a rubber mallet.
            #25692
              Sent you a PM.
              Check your messages
              at the top of this page.
              #25999
              greg-o
                I also have one that is stuck. I have been soaking it now for several years. When I get time and motivation, what I am thiniking of doing is take an old spark plug, gut it out and fabricate it so I can screw a grease fitting into it, then screw it into the spark plug hole, and start pumping grease. I should probably do both cylinders at the same time. I realize once the pistons hit the ports they will not move any further, but a least I will be able to get them to move.
                #26015
                2fast4me
                  Well the mercury KD-4 came home with me. Stuck. I tried penitrating oil for days, no help. So i removed the cylinder holdown hardware and fabricated an adapter from an old spark plug, pipe, coupling and grease zerk and pumped away. The cylinder started moving but was tight all the way out. The rings are all stuck in the lands everything was covered with varnish. I don’t think mine would have come apart without extreme intervention.
                  2Fast4Me
                  #26039
                    Greg O
                    Sent you a PM.
                    Check your messages
