Home › Forum › Ask A Member › Johnson A-25, SN 46333 – Won’t turn over
- This topic has 19 replies, 11 voices, and was last updated 5 years, 1 month ago by
JOHN HOLBIK.
July 24, 2020 at 12:17 pm #209701
I’ve cleaned this motor up pretty well -checked the compression, good spark, checked the coil/condenser, cleaned the carburetor, done the lower unit and water pump, replaced screws, polished the fly wheel…. CAN”T GET IT TO TURN OVER. This is the first Johnson I’ve worked on and since I’m fairly new to OMCI haven’t used this forum before. Thought I’d ask for suggestions – much appreciated.
HarrisonJuly 24, 2020 at 1:16 pm #209704do you mean its seized
July 24, 2020 at 1:16 pm #209705
This reply was modified 6 years, 3 months ago by
Tubs.
July 24, 2020 at 2:18 pm #209715No, when I pull the cord, combustion will not take place and start. Pistons are not seized, have good compression. Can’t get it to fire up.
July 24, 2020 at 4:50 pm #209727How did you check the spark? It’s harder to make a spark in compressed fuel/air mix than in open air.
http://www.omc-boats.org
http://www.aerocraft-boats.orgJuly 24, 2020 at 5:36 pm #209729Checked it in open air in an unlit garage – nice blue flame. How do you check it internally?
July 24, 2020 at 6:11 pm #209734open air 1/4in gap
July 24, 2020 at 8:47 pm #209749When you say “checked the compression”, was it with a gauge, or just by feeling the flywheel bounce ? In my experience, not much under 50 lights up or runs well.
If it is Ok , then you’re left with fuel/air mix and supply, are the rods connected to the correct side of the crank and if the rods are in the right place are the pistons upside down on the rods.
Carb lever needs to be on “S”, mixing needle about 1 to 1 1/2″ turns from lightly seated.
Spark advance lever should be just to the right of the centerline of the crankshafts whilst you are sitting facing aft.
If you have decent (60+) compression and the innards aren’t all scrambled, it becomes a matter of making small changes one at a time to the carb lever, mixing needle and advance lever.
Oh, and fresh fuel, 8:1 ratio.
July 24, 2020 at 10:26 pm #209759A small correction:carb lever should be pushed all the way down to “C” for choke,then moved to “F” when engine starts.
July 25, 2020 at 8:43 pm #209850Thank you — I did mean C, but my fingers typed S 🙂
