Home › Forum › Ask A Member › Johnson 5.5 CD 12….Having trouble putting back on the black handle
- This topic has 8 replies, 5 voices, and was last updated 4 years ago by
Don.
October 29, 2022 at 12:56 pm #268395
Hi, I am done painting my Johnson 5.5 HP CD12. I am trying to put back the black handle and am about 1/4 short of where I can put it on and screw it in. It seems like the handle should extend about 1/4 past the black line rim to line up but I cant push it any further. Is there a trick to this ? Thanks for any help
October 29, 2022 at 1:07 pm #268398Do you have the D-shaped notch in the grip (handle) properly aligned and engaged with the D-shape end of the shaft? Also be sure the tabs on the friction block are aligned and sliding into the notches on the end of the tiller handle.
This reply was modified 4 years ago by
Bob Wight.
October 30, 2022 at 7:02 am #268441Good advice from Bobw. Also, make sure the friction block isn’t installed backwards. I have good results by lining up the flat part of the friction block, the flat side of the tiller shaft, and the tiller grip screw hole at 12:00. Push the tiller grip on with slight pressure. You may need to turn the grip slightly one way or another for the tab and slot to seat. Once seated, hold the pressure on the grip, and install the screw. It’s a little tricky at first but will be easy after doing it a few times.
Improvise-Adapt-Overcome
October 30, 2022 at 7:19 am #268442Sometimes the friction block gets stuck in the handle. Make sure you get it out and clean it. The old grease and gunk causes the handle to turn hard. The spring pushes on the friction block in the handle. There are a couple ears on the friction block that need to line up with the slots on the tiller handle. Usually that is the problem getting the last quarter inch, so you can get the bolt in.
hope this helps
dale
October 30, 2022 at 9:03 pm #268464Dale, Thanks for this advice, much appreciated
October 30, 2022 at 9:05 pm #268465Bob, Thank you, will be trying to line this up tomorrow morning
October 30, 2022 at 9:05 pm #268466Auquasonic, Thank you
October 31, 2022 at 6:35 am #268469Thanks everybody, IT WORKED, and thanks so much for the input, would never have got it on my own. 4 hours on getting the handle back on, good learning experience, and again, everyones advice helped me to get it, had no idea I could get that piece out within the back of the black plastic handle , clean, align, etc.
November 1, 2022 at 9:47 am #268540Sometimes, having an assistant can make this assembly process easier as well. Kind of tough getting everything lined up, and the screw located and started (without crosss threading it) with just two hands.
