Home › Forum › Ask A Member › Johnson 5.5 carb issue
- This topic has 19 replies, 7 voices, and was last updated 11 years, 6 months ago by
archangel.
May 9, 2015 at 5:48 pm #15594
If you pump the primer, and fuel spills out from the air horn, the float is not floating, or the needle is not seating.
Perhaps the float is catching on the gasket?
Perhaps the float is upside down? Not to say you did that, but has happened on here before!
Dirt in the seat?
I test the carbs before installing. Once put together, hold it upright and blow into the fuel inlet. You should be able to.
Now flip carb upside down. You should not be able to blow into it now.
I do this after I clean, as I hate the taste of gas/oil mix π
May 9, 2015 at 5:51 pm #15595As a second thought, the float could be catching on the gasket, if the drop is set too low. See the tab on the float arm, the one that hits the casting for the needle/seat? That can be adjusted, to give you proper float drop.
If that tab is sticking up in mid air, the float is upside down.
EDIT: Is the float original? If so did you coat it? Test it in a bucket to ensure it actually floats?
May 9, 2015 at 6:53 pm #15600To my great embarrassment, I had installed the spring clip on the float needle upside down. It was the only thing I didn’t think to change in all of the on-and-off, apart-together with the carb. The motor runs like a top from the first pull. I don’t think it will even require much carb dialing-in. Not the first time I have made myself look stupid and I know that it won’t be the last. I hope that someone else can resolve the same issue quickly for themselves now that I have documented my stupidity. π³
To answer your last questions, Chris, it is a new float that came with a completely new BRP rebuild kit and was installed the correct way except in the one instance I noted above where I doubted myself and flipped it over.
Thank you all for your suggestions. π
May 9, 2015 at 7:00 pm #15602Great! Now she is ready for the water!
I have found, that my stupidest mistakes, are the ones I remember the most.
No mechanic gets to the experience they have, without destroying things and making mistakes. That’s for sure.
May 9, 2015 at 7:06 pm #15603I agree with Chris and I can remember questioning which way that clip fits. Glad you got it!
Improvise-Adapt-Overcome
May 9, 2015 at 7:33 pm #15605Very charitable of you both! As I said, I hope someone else can learn from my slow-wittedness and save themselves some future Saturday boating time with the thread on here now.
May 12, 2015 at 12:48 am #15756clean the carb…
adjust everything & before mounting it blow air with your mouth on the fuel inlet …….. air should flow into the carb body
turn it upside down and redo the blow test… air SHOULD NOT pass the inlet needle. if it does that is why fuel is spilling out of the carb when you squeeze the bulb
find out why…. maybe the float is snagging …btw you do have a good float ?
May 12, 2015 at 2:13 am #15760Don’t beat yourself up – You are not the first, and definitely not the last to be confused as to which way that clip went.
. . . . . π
May 12, 2015 at 11:23 am #15776Glad the problem is solved. Nothing we all haven’t done before, enjoy the engine!
May 12, 2015 at 11:39 am #15777Thanks, again, to all of you for the advice and encouragement. I won’t make that mistake again, so that’ll free up room for lots of other mistakes for me to make π
