Home › Forum › Ask A Member › Johnson 200 & 300
  • #6219
    kevinrude
      Where is the water discharge on these motors?
      #52043
        On the port side near the transom clamps.
        https://www.youtube.com/watch?v=-wWAGHnOwGg
        #52046
        kevinrude
          quote Mumbles:
          Glad I asked. I wouldn’t have looked there in a million years! Thanks Mumbles.
          #52107
          spike
            300 yes, 200 not so sure!
            #52116
              Good point. The 200 doesn’t have a water pump and uses the pressure-vacuum system found on other Johnsons of the era. The discharge outlet is under water, in front of the prop.
              #52138
              kevinrude
                quote Mumbles:
                OOOOOOO, so the only way to tell if the water is in fact running through the system is to put your hand near the cylinder and see how hot it is? OUCH!
                #52139
                dougs-outboards
                  Or.. you could put your hand down by the prop and feel the discharge…. NOT!
                  #52140
                    Or carry an infrared thermometer with you. It’ll let you know if the motor is hot without burning your hide!
