Home › Forum › Ask A Member › Johnson
  • #301798
    Dennis Muchow
      I acquired a Johnson Model no.  4 D39X, Serial no.748204, does anyone have what year manufactured and what it is
      #301802
        Hd39 was made in 1939     post pictures or recheck your mdl #      H or 4..D
        #301806
        David Stanton
          748204 is a 1949 serial number, but there are no model numbers close to that in 1949. Maybe your post has a typo? There were four models in 1949 that had a D as part of them. If model and/or serial numbers are hard to read, please post a photo or two.
          #301813
          Sam M.
            Was yours made in Canada?  I have a Canadian-built Johnson outboard with a serial number that does not line up with the American serial number records, but rather with the Canadian production records.  The Canadian vs American serial numbers were waaay different numbers for the same year.
            #301846
            Dennis Muchow
              Thanks I am not sure where it was manufactured, obtained in Iowa
              #301875
              Dennis Muchow
                how does one post picture
                #301876
                NATHAN KILLIAN
                  US Junior Member
                  click the “select file” button and open your photo.
                  #301878
                  NATHAN KILLIAN
                    US Junior Member
                    You may need to resize the photo so that the file size is not too big(must be less than 2 mb).  If you are emailing a photo from your phone to your computer(as is easy for me at least), assuming you are using Gmail, when it asks what size of photo to use, select one of the smaller sizes so that the file size that is emailed is automatically small enough and you do not have to resize it.  Then you can upload the file onto your computer and upload the file to the website.
                    #301887
                      I just move them to powerpoint and shrink them ..
                      #301889
                      Dennis Muchow
                        here is a photo of model no. showing a 4
