Home › Forum › Ask A Member › ISO ’59 Super Seahorse pump impeller advice
  • #44406
      I usually put a bit of grease on the tips of the vanes, just to ease in lowering the housing down onto the impeller though.
      #44407
      wetwillie
        quote 1946Zephyr:
        However, I would definitely apply a coat of sealer on the bottom side of the wear plate, where it mounts to the gear case.
        They don’t pump worth a darn, if the bottom side isn’t sealed properly.
        Thanks! I didn’t remove the wear plate and, based upon how well everything else was sealed, I have every reason to believe its well sealed too.
