Home › Forum › Ask A Member › Is This Part of an Outboard Motor? 2 Weeks of Google Image Frustration Inside
- This topic has 20 replies, 16 voices, and was last updated 9 years, 4 months ago by
larkbill.
July 3, 2017 at 4:40 pm #7524
A buddy gave me (what I presumed was industrial machinery, of sorts) the highly oxidized item as a gift. According to the provenance my friend was able to provide, the motor(?) was found in the Chesapeake Bay, close to the (now bankrupt and vacant) Bethlehem Steel Plant. I’m able to pay a few bills doing restoration work, but it’s mostly a hobby. I’m very impulsive, and jumped into the project before doing any research.
Boring story short, I’ve been searching the web exhaustively in hopes of identifying this thing, which finally led me here(thanks to the admins for an extremely painless registration/approval process). My ladyfriend plans on making a stained glass lamp, using this thing as the base, and I would consider myself in the debt of anyone that could help identify what it actually is, and put me out of my misery.
Thanks in advance.
Cheers,
ryno
July 3, 2017 at 5:10 pm #60891I don’t know?
July 3, 2017 at 6:45 pm #60894Looks like some sort of pump mechanism.
July 3, 2017 at 7:04 pm #60895Certainly not an outboard motor that I’ve ever seen nor heard of.
July 3, 2017 at 8:15 pm #60900Anonymous
It might be a regulator from an old air compressor.
That brass valve might be a Pilot valve.
Just a thought.Steve A W
July 3, 2017 at 8:19 pm #60901looks like a single piston diaphram pump. Not a high volume pump either. Probably for moving bulk fluids. NOT for one of our submarines though.
July 3, 2017 at 8:28 pm #60903I think it is a signaling device, Not sure what it is porting without circuits shown. It is missing a few parts I believe too.
July 3, 2017 at 8:52 pm #60905I’m thinking a pressure or flow regulator; looks like a diaphragm between the two cast iron pieces, the slight movement of the diaphragm armature operates against the toe of the boot; boot movement is regulated by the tension spring, which is adjusted at the firm end. ❓
July 3, 2017 at 9:42 pm #60910Looks like version 1.0 of the "Flux Capacitor". Or maybe the very rare "Clevis Pin for the Clatterhorn"?? I don’t think it’s a "Kuneutter Valve" either….
Maybe someone can verify the Flux Capacitor? Garry? You’ve been around as long as anyone I know! Got anything ideas??1Aquaholic
July 3, 2017 at 9:43 pm #60911Possibly an unloader valve from an old, large compressor.
