Home › Forum › Ask A Member › Is It me… ? PM replies don’t work
  • #275968
      anyone alse have  issues with      REPLY  on PM’s
      #275969
        NOT HERE
        #275970
          True, the replies to PMs sometimes don’t respond when you press reply/send.  Oftentimes it take a minute or so before the reply will go through.  And, if you go away from the page before the reply goes through, it is lost.
          One other big frustration, and you would have thought I would have learned by now…. PMs from this site are usually delivered to my email address as well (gmail), which is fine.  I spend several minutes typing a detailed reply, only to be told you can not reply here/via email, this happens after you type the lengthy response and hit reply from the personal email…
          #275971
            Yeah, my PM replies usually don’t work. You type a big ol’ reply, hit send and…..crickets. Nothing. When this happens, being half Irish, you could light a cigarette off my forehead.
            #275972
              #275973
                I don’t have any problems posting.We all must remember the computer is not perfect & the voninteers try very hard to keep the ball rolling. Just my view. I had problems with my cable service & they said I have a bad router. After replacing the trouble persisted. I replaced the input splitter they provided & that fixed it. My system is split before entering my home, one goes to the computer & the other to the T.V.’s. I have found major differences in the quality of signal spliters. Just my  experiences.. P.S. Use RG 8 coxial wire too. Higher quality coaial cable than the I.P. installs.
                #275975
                Dimce
                  I have issues replying also, I need to copy the text then refresh the page a few times and then paste and send.
