Home › Forum › Ask A Member › Interesting "Antique Outboard Piston Un-sticking Tool " on the Bay
- This topic has 8 replies, 7 voices, and was last updated 10 years, 11 months ago by
beerman57.
December 14, 2015 at 9:36 pm #3178
http://www.ebay.com/itm/Antique-Outboar … 0Y&vxp=mtr
December 15, 2015 at 1:34 am #28632At first I said to myself "that’s not an antique tool!" š³
The same seller is offering a puller that looks similar to an OMC but at a cheaper price. Even so, I’ll probably just stick with my harmonic balancer puller.
http://www.ebay.com/itm/Outboard-Flywhe … SwNphWW4r4
December 15, 2015 at 2:33 am #28637It wouldn’t have moved the #4 piston on my MK55. but look at my ad for the other 3 pistons – pretty nice shape. I broke out the top of the cylinder / put one of my trucks front tires on the block and pounded on the piston with a block of wood and 2lb. hammer. Before I got the piston out, I remembered that the cyl. sleeves are steel, so the block can’t be scrapped as alum. It’s such a shame, that motor could have been rebuilt a long time ago, but now the block and crank are junk!
December 15, 2015 at 4:14 am #28642Will the schrader valve hold up to the pressure if using a grease gun?
December 15, 2015 at 4:19 am #28643Seems so barberic to slam it like that! Seems a quite a shame to destroy it.
December 15, 2015 at 6:00 am #28644Just looking at the safety aspect. I witnessed the effects of high pressure on soft tissue before.
December 15, 2015 at 10:42 am #28645quote Jeff Register:Seems so barberic to slam it like that! Seems a quite a shame to destroy it.If you’re talking about the Mark 55 block, I had the exact same situation. Believe me, sometimes those pistons are just not going to budge, no matter WHAT. In my case, I actually cut the block off the piston. This was more a matter of determination than common sense; as I knew the crank would be no good too…..and it wasn’t any good. At least I got three good pistons and rods for my effort. Better than junking the whole long block.
As for the tool, it looks well made. I agree that the Shraeder valve may not handle 1000 psi but maybe you’re supposed to switch the valve and the fitting as needed?
December 15, 2015 at 2:01 pm #28652He also lists one with a grease zerk similar to one I made out of old spark plug. You’d be surprised how much hydraulic pressure a heavy duty grease gun puts out. If that doesn’t get the piston out, nothing will.
December 16, 2015 at 2:13 am #28675I got 3 great piston and rods too, just went about it a different way. I was able to get the rod caps off and remove the 3 good pistons before destroying everything else. I had 3 beautiful journals on the crank, but 3 out of 4 IS bad!
