Home › Forum › Ask A Member › Initial needle valve settings JW-10
  • #5020
    justintime
      Can someone give me the initial needle valve settings for the jw-10?
      Secondly, verify that the very sharp longer needle is the low speed needle. Thank you for your support.
      #42373
        Correct, sharper needle is for low speed.
        In general, most 50s omcs can start with the low speed needle out 1.5 turns from seated, and the high out 3/4 from seated, then tune from there.
