Home › Forum › Ask A Member › Info re oil seals for prop shaft on 301 elgin
  • #7994
    leeinnh
      I have several of the 1.25 hp elgins, but the 2 recent acquisitions have standard oil
      Seals on the prop shaft at the gear case, as opposed to the original 2 piece system
      Anyone have these oil seals? Size, dimensions, whatever needed. Maybe a part number?
      Thanks for any help.
      #63684
      leeinnh
        ok. I was able to replace the seal with "shower head washers " -2 fit just right, an a correct sized steel washer as
        the clamp, pressed on with my vice. pretty much the same as the original system.
