Home › Forum › Ask A Member › Induction motor running unbalance current
  • #1982
    redwing
      I need some advice what need to do for maintenance if motor run at current >3% derating…
      Either need check the looseness, swap phase cable to verify or else.
      Need someone to advise.
      Tq.
      #19821
      mercuryman
        HUH !
        #19822
        legendre
          quote mercuryman:
          HUH !
          My guess, he’s asking about an imbalance in currents drawn by a 3-phase induction motor. Basically, the currents should sum to zero, but often they don’t.
          Anyway, if it’s only a 3% imbalance, that’s nothing to be concerned with. Oh, and this is entirely the wrong forum for this question.. 🙄
          #19882
            It may just need a little oil in the bearings …
            Sealed ball bearings may need replacement if noisy or running hot.
            #19899
            mr-asa
              Have you tried running non-ethanol gas for your mixed fuel?
