Home › Forum › Ask A Member › improving water flow
  • #5024
    JOHN D.
      Lately i have been barrel testing a couple old neptune outboards. They don’t pump water very well. I have tried raising the water level and removing the prop to help to no avail. Has any body ever rigged up an external pump on the water exit pipes to aid in cooling? It seems that the neptunes are bad for this.
      #42390
        #42394
        cajuncook1
          quote Tubs:
          On motors that have tubing running from the pump to the
          power head I have make and adapter to attach a hose to
          run water though the cylinders in the direction the pump does.
          Tubs, I would greatly enjoy seeing the modification you are discussing.
          Cheers,
          David T.
          #42398
          JOHN D.
            On the 15A6 motor it would be easy to remove the rubber hose and put a tee fitting there. On the others the copper tubing would have to be disconnected. Might have to start testing them outside the barrel.
            #42399
              #42423
              JOHN D.
                I took an 8 inch piece of 1 inch copper tubing and cut it lengthwise. Heated it up to red hot and quenched with water. Then it was soft enough to form around the water intake. I’ll get a female hose fitting for this and silver brase that to the copper. Then make a gasket to fit. Strap it on with a bungie or what have you, and Viola! Now on to finish the project.
                #42436
                  #42444
                  JOHN D.
                    I have all those odds and ends. Hope to try this out today.
                    #42472
                    cajuncook1
                      quote John C:
                      Tubs, thanks for showing me examples of your water tube adaptors!!! Pictures help a lot, because I’m primarily a visuals learner.
                      Cheers,
                      cajuncook1
                      #42484
                        quote Tubs:
                        Stuff that gets
                        guys like mumbles, Frank R., T-2, and
                        Richard White shaking their heads.
                        I don’t shake my head bro, I nod with amazement! ☺
