Home › Forum › Ask A Member › Impeller source for Chrysler/Sea King
  • #5172
    terriblecj
      Anyone selling these? I have a 20hp Sea King from 69’/70′ that needs a new impeller. I poked around but the Chrysler/West Bend stuff confuses me. Thanks for any help.
      #43365
      David Stanton
        If the motor happens to be a ’73 or newer, Chrysler used Sierra # 18-8903 on everything from 10 to 25 HP for several years – if it’s really a ’69 -70, it may not fit.
        #43371
          Confuses me too. Laing’s Outboard Service says it takes a 901065, not available.
          #43373
            bill-russell
              You can get that impeller from any Mercury dealer, part# f436065. Bill
              #43382
              amuller
                I think you want an F-436065 or Sierra 18-8903. These fit a wide variety of motors in the West Bend/Elgin/Chrysler/Force lineage. I just put one on a 1957 Elgin (West Bend) 12 hp. These fit 1/2 in drive shafts. I’m not sure at what power they went to a 5/8" shaft. That uses a different impeller.
                At the moment, $12.27 from Amazon.
                #43408
                terriblecj
                  Sweet! Thanks guys, I’ll definitely give that a shot!
                  #43790
                  terriblecj
                    So, when taking the lower unit off, it drops about an inch or so in reverse and there was a screw holding a "hook"-like clamp in place. Looks like the rod goes into a plastic shaft? I removed the clamp but nothing happened….Do I need to remove the powerhead to remove the lower unit?
                    #43796
                      I confess I have no idea what you are describing. Doesn’t it have an external turnbuckle shift rod connector beside the exhaust housing? That would be so typical Chrysler.
