Home › Forum › Ask A Member › Impeller on 1952 evenrude an 1953 Johnson
  • #282973
    Donald Keller
      Do you have to pull the head on the 1952 and 1953 evenrude and johnson  25hp motors to unhook shift rod to change the impeller like you do on the e enrude and johnson 5.5 and 7.5 motors. Thankyou in advance for info..
      #282974
        No.
        #282975
        Donald Keller
          Thanks…where do I separate the shift rod at ?
          #282976
            if you drop the GC an inch  or so you should see the shift link connector inside… loosen the bottom bolt
            #282977
            Donald Keller
              Ok…thankyou  Crosbyman..
              #282978
                you should download the bible  Johnson service manual … all that info is available for you.  see sample picture
                https://watercraftmanuals.com/outboard/johnson/manuals/johnson-302231.htm
                the book covers everything you need
                I do not have the picture for your model .. some have side plate you can open up to reach the shift connector .
                #283009
                Donald Keller
                  Thankyou…I will try to down load this johnson bible…not sure my phone can handle it…I don’t have a computer
                  #283010
                    pretty big file !      178 190 K bites
