Home › Forum › Ask A Member › Impeller Johnson hd25
  • #7929
      With water pump assembly open, no rubber impeller found. Where can I buy one? Any pictures of impeller?
      #63268
        Here is a Similar impeller on a Gale motor. . . 🙂
        #63271
          I should have mentioned that the red space is supposed to be on the outside of the rotor. That rotor has swelled cutting down on the water pumped. . . 😉
          #63406
          punchbug
            DO you have a part# I have one that looks like that but I need a part# so I can find it. Just found the impeller I have #550040 the price is $8.50 CND plus shipping. Check the number to ensure it is the right one. Mine is NOS.
            #63416
              That water pump rotor is for the 5 horse Gale around 1950. He needs a 300463 rotor for his TD Johnson. . . 😉
              #63427
              aquasonic
                For the HD model, the part number for the rotor is 300583.
                Improvise-Adapt-Overcome
                #63430
                opposedtwin
                  I imagine dan gano has them. There should be a link on our links section.
