Home › Forum › Ask A Member › Impeller housing
  • #279613
    I have a 1956 Buccaneer model 5d13b 5 hp! Went through lower unit, and had to patch the lower impeller housing! Is there a new part available that includes the lower housing, put in a seal kit! Found several impellers and housing online, that were new! Unable to locate one for mine, any suggestions?
    #279616
    CHUCK
      It looks like you need part# 376074.     You could place a Wanted ad here.  It’s free to place the ad here..
      Pg-20-Gear-Case
      Pg-21-Gear-Case-Parts-List
      #279650
      David Stanton
        376074 is now 382796, and it’s available new but you won’t like the price:
        https://www.marineengine.com/newparts/part_search.php?part_num=376074
        #279661
        Thanks outbbnut2!
        that is a little high! Will have to weigh it out with a used one!
        #279663
        CHUCK
          Thanks outbbnut2!
          It might be time for you to do some research as to what other  model motors used that housing and start to be on the lookout for a parts motor.
          #279664
          CHUCK
            Apps-for-Housing
            #279708
            Thank you seakaye12
            #279711
            Steve D
              “It might be time for you to do some research as to what other model motors used that housing and start to be on the lookout for a parts motor”
              If you were going to do what CK mentions there, to help broaden your search for a cheap parts motor, the 50s and 60s 5-1/2 and 7-1/2 HP and maybe the first few years 6 HP use that 376074 bearing housing and the 300599 > 327031 seal.
              #279727
                I have  purchased several  good  5.5 and  7.5 for half the price of that part !!!   somebody must have s dead one in a shed or barn !
                #279930
                Im on the hunt! Thanks man
