Home › Forum › Ask A Member › Impeller housing
  • #290246
    Tinman
      IMG_3731
      Should I use this or replace? Pitted but still somewhat smooth
      #290251
      Jeff Barsch
        Tinman, I have reused housings that look like that with no issue on my smaller motors.    I would lightly clean with scotchbrite and use an oem impeller  though if you do.
        1954 Evinrude 7.5 HP
        1954 Evinrude 15 HP
        1954 Gale 12 HP
        1955 Johnson 10 HP
        1956 Johnson 10 HP
        1956 Gale 12 HP
        1956 Evinrude 5.5 HP
        1957 Johnson Golden Javelin 35
        1958 Johnson 7.5
        1960 Evinrude 18 HP
        1973 Johnson 6 HP
        #290320
          I would probably just smooth it up with some light emery and try it out.  How is the SS impeller plate?  Consider replacing the housing/plate if water pump performance is weak..
