Home › Forum › Ask A Member › Impeller for 1953 Firestone / Corsair 10 hp (Scott made)
  • #301423
      Whoops!  I’m always accidentally swapping digits!  For 18-3028 everything I’ve found says it’s a woodruff key for a Yamaha.
      I found that number in an old chart, and it said it was
      for McCollough, and it appeared to have the correct dimensions.
      I had the same luck as you though in searching for said impeller.
      CHUCK
        That Woodruff Key shows up because Sierra has been known to re-use old 18-xxxx numbers.  That is so dumb IMHO.  I have encountered that several times now;  the number for something that they discontinued decades ago is now being used for something completely different.
