Home › Forum › Ask A Member › ignition timing
Viewing 4 posts - 21 through 24 (of 24 total)
  • #197047
    RICHARD A. WHITE
      Already stated, so I won’t repeat…lol
      classicomctools@gmail.com
      #257468
      David C
        i playing with my 1951 4443 7.5 fleetwin havent been able to get it to run good yet so im checking the timing as per video.Dont see any marks on flywheel for front or back cylinder? Thanks DaveR
        #257471
          poke a pencil in an open  plug hole   find  exact TDC  by rotating the prop in gear that is where the points must  “just”  open  for that cyl   (front coil is top points     back coil is bottom cyl. points)
          otherwise find the high spot on the cam and set points at 0.020  after a good clean up
          #257472
            see pic
