Home › Forum › Ask A Member › Ignition component testing
  • #1653
    joshadurham
      How does one professionally test ignition components? What special tools are involved? I know there are many ways to go about it as far as assuming and replacing, but that gets expensive and frustrating. how does one do a proper check of each component? Do you need a special tool like a mercotronic tester? or will a multimeter do the trick. I want to learn how to diagnose problems the right way, and avoid replacing expensive parts with nothing but a guess.
      Thanks
      #17343
        cant beat the merc-o-tronic.
        #17350
        debe
          Merc-o-tronic probably the most versatile instrument you can get. Was lucky enough to find one in the local scrap yard for free. And it had the CDI test function.
          #17365
            Yeah I tried for years with meters and such, but now that I have the proper Mercotronic, Ill never go back!
            #17398
            joshadurham
              looks like I need to find a Merc-o-tronic! Anyone got an extra they want to sell? Do they make one that plugs in rather than battery operated?
              #17399
              handyandy
                Basic testing with a multimeter:
                Coil Testing:
                http://www.pochefamily.org/outboard/coils.htm
                Condenser Testing:
                http://www.pochefamily.org/outboard/Con … sting.html
                #17400
                mr-asa
                  Without having used a Merc-O-Tronic, I have yet to find a tool that will beat my Fluke multimeter for electronics testing.
