Home › Forum › Ask A Member › Ignition coil question
  • #258352
    hondaatc
      Hey fellas i have picked up a lauson twin outboard with no spark it looks like it has a replacement coil my question is should the ground and the wire to the points be connected at the same point on the coil i dont see any other leads coming from the coil thanks
      20220415_185259
      • This topic was modified 4 years, 6 months ago by Mumbles.
      #258354
        I don’t see how it could work that way.
        #258355
        hondaatc
          Thats what i was thinking
          #258359
            The black wire is not connected to the braided wire correct. if so, the braided wire goes to ground and the black wire to points and condenser goes ti points also.
            #258360
            hondaatc
              Yeah I’m confused
              #258361
                Call Me 1 914 310 7086. Dave.
                #258362
                hondaatc
                  Thanks dave i can give u a call tomorrow if thats ok
                  #258372
                    yes, it is.
                    #258415
                    JOSEPH BRINCAT
                      Maybe it’s just an illusion… the insulated wire may just be in close proximity to the ground solder lug. Did you check with a ohm meter? should be seeing a low resistance thru the primary winding, like 2 to 5 ohms. If you get “zero” you have a problem.
                      #258445
                      hondaatc
                        Hi dave i haven’t forgotten about u i think i might try the maytag twin coil that i have seen on some other forums here anyone know what one exactly ? I am looking at this one … picture attached…
                        James
