Anyone know what this tank fitting is? Similar to older Merc fittings but much smaller. Looking for the male fitting. It has a pin bottom right that when depressed is the tank vent. Thanks, Bruce
Mercury used a smaller version of their typical bayonet fitting in the early sixties thru 1971. I see them on the smaller motors; the 3.9’s thru the 9.8’s.
I think it’s Mercury part # 30635T3 for the male end.
Thanks for the suggestion, I’ll take a look at it. The problem I see though is the vent pin on the tank flange. The fuel line fitting needs to depress the pin to vent the tank.
I was also thinking that Scott used a bayonet type fitting, but the vent pin issue would seem to require a fitting with a flange that would interface to the pin.
