Home › Forum › Ask A Member › I have angler issues
  • #31584
      Here is what the beast looks likeL
      pic host
      how to take a screenshot on a pc
      #31586
      wedgie
        Wow Frank, Thanks for going to all the trouble !
        Thanks Ed. If your prop will fit I’d be interested. 😉
        If I can’t find a usable prop I guess I will keep this motor for parts for a 6 horse.
        #31600
        melugin
          I have a NOS Michigan wheel PJ-7, 8 x 7 1/2, 3 blade aluminum prop, last one here. This is the economy model which does not have the clutch hub, as the AMC Michigan prop. Send me a PM if you are interested. Shipping may cost more than the part, though.
          #31616
          bbstacker1
            Just happens to be one listed on ebay right now, not very often they come up.
            http://www.ebay.com/itm/201517647241?_t … EBIDX%3AIT
            #31618
            enrico-italy
              The thermostat was optional in Anglers.
              The cylinder head is exaclty the same of 6 hp, so it is easy to put it in place.
              The correct prop is a 8" x 7.5" x 3 blades, left handle, and is essentially similar to the 3 hp one, with the same shear pin and rubber ogive.
              I wondered the 5 hp can use a longer pitch than the 6 hp with the same gear ratio ( the 1976 and later 6hp uses 12:25 ratio and 8×7 prop instead of 15:26 and 8×71/4 of first series) but it is…
              I have a ’66 johnson LD 11 and I will check if a part number is on its prop.
              #31619
              enrico-italy
                oops… too late… I’m sorry…
                #31634
                wedgie
                  You guys are awesome.
                  I suppose I should get this Angler running first before I spend anything on it. I have a whole pile of 30 other motors to go through too and see which ones are viable to get running or just part them out. Up until now I had never considered trying to recoup my investment in this hobby.Now I have to due to space limitations with the doubling of the inventory overnight.
                  Thanks again everyone for all the info 😀
                  #32300
                  wedgie
                    I found a prop in my attic that I’d forgotten I had. Thanks for all the prop offers and indeed, I may need another one at some point for another motor.
                    Popped in some fresh coils, cleaned the points, didn’t even touch the carb and it started on the 3rd pull.
                    http://vid635.photobucket.com/albums/uu … d6lucs.mp4
                    #32316
                    melugin
                      Dandy!
