Home › Forum › Ask A Member › Hydraulic tilt for 1963 and 1970 40hp Evinrude / Johnson
  • #1863
    Monte NZ
      Hi everyone.
      Was there ever a hydraulic tilt unit available for the above motors.
      I had a hunch that I had seen one several years back on a 40hp Johnson.
      Age is catching up with me and I thought it would be interesting to see if they were ever produced, as it could make boating a bit easier
      if I could find one.
      Thanks in anticipation
      Monte NZ
      #18946
      Michael Anfossi
        International Member
        No OEM tilt for these motors. Could adapt an aftermarket one. CMC make one for example that will work
        #18947
        kerry
          Never heard of, or seen a factory tilt for Big Twins, but CMC Marine offers a power tilt and trim unit for motors up to 35hp- but since modern 35’s are propshaft rated and/or four strokes (heavy), it should be fine for older 40hp motors. http://www.cmcmarineproducts.com/produc … p-to-35-HP
          #18959
            You guys ready for a surprise? Check this:
            #18971
            kerry
              Okay, but I still haven’t seen one in person…. have you, Frank? Got to be pretty rare if they do actually exist. ($$$$$$)
              #18985
                Nope, I can’t say that I’ve ever seen one. But marineengine has a 172070 (33hp) for $400. Did somebody mention $$$$$$? The electric/hydraulic power unit was also used on other models, which I’ve seen. But I don’t know what sort of contraption it uses on the 33-40.
                #19017
                kerry
                  As scarce as it may be, I will still bow to the Master. Well played, Frank.
                  #19067
                  Monte NZ
                    Hullo everyone.
                    Thanks very much all of you for your replies and thanks too Frank,for posting the 1970 listing proving that they were available…….my memory hasn’t gone to the dog’s after all!!!
                    The price of $400 US, when converted to New Zealand dollars plus freight plus GST would make it a very expensive exercise!!!
                    I guess even in USA, the $400 dollar price tag would put a lot of people off purchasing one.
                    On the basis that you chaps haven’t seen one over your way,the chances of picking up a second hand one here would be most unlikely.
                    The only other thought I have ,is would it be possible to modify a tilt unit of a later 50hp?……….I will see if I can learn anything from dealers down here.
                    Thanks very much again for your input………you certainly are a very knowledgeable bunch of guys!!
                    Keep up the good work!
                    MonteNZ
                    PS I will check out the price at CMC Marine just for curiosity,but I suspect that it will still cost a lot.
