Home › Forum › Ask A Member › How to wire cutoff switch for 1970 Evinrude Triumph?
  • #294461
    Steven Lichty
      I have repowered my Penn Yan with a 1970 Evinrude 60, which has the Hydro Electric gearbox and controls. I’m restoring the control box; stripped and repainted, new decals, etc.  I’ve found a new roller switch on ebay (there’s a guy 3-D printing them; nice switch). I would like to also wire in an emergency cut-off switch. I have one that clips to your PFD which pulls out and connects the circuit and shorts out the motor if you go overboard. I assume I can wire the two wires to the back of the ignition switch, but not sure which two posts to wire it to. My prior motor was an old Lark II with a magneto ignition; for that one I ran the switch between the two magneto wires on the back of the ignition switch, but this motor and switch is different. Any guidance from anyone would be greatly appreciated.  Thank you.
      #294469
        Classic Whaler: Boston Whaler: Reference: Wire Color Code
        see yellow black ..grounding  it should kill the engine
        #294479
        Gary H.
          Great info Crosbyman. The kill wire is black with a yellow tracer to clarify.
          BLACK = Battery negative
          BLACK with YELLOW stripe = KILL Switch (grounded to stop engine)
          #294480
            yes..
             info is provided  from the document . up to you to try it out..
             as diag. the switch joins black M  to  BLACK_YELLOW in the OFF staee
            #294481
            Steven Lichty
              I appreciate the responses, thank you.  I studied the attachment provided by the link, and it doesn’t seem to correlate with my wiring; there is no black with yellow stripe in the harness at either end; under the cover at the motor or at the ignition switch. I tried to upload a couple pictures, but the 2 MB max file size does not allow the picture I took on my iphone of the switch and of the 1970 Evinrude Service Manual wiring diagram that I have for the Triumph 60.  Is it possible to wire the cutoff switch between any of the posts on the ignition switch? Essentially I’m looking for the same response as turning the key to off. Thanks.
              #294484
                if you piggy back on the switch wires you should be able to recreate the  kill condition but.. not having the exact  wire diagram is a  flip of the coin.   the  pictoral   “secondary doc. link”  document in the link  above  above shows various key functions which  your key switch should duplicate.
                try googling your engine model wire diagram
                #294503
                  OK, this engine has battery CD ignition, no black/yellow stop wire used here.
                  The best way would be to put a safety switch in between the battery B+ post and the lead connected to it…  That being said, I don’t recommend doing this, unless you use a rugged/reliable switch and do the wiring in a way where it won’t break/get chafed, etc.  There is not much room inside that box…
                  #294504
                    You are right…
                    This engine uses “battery CD” ignition…  It needs battery B+ to engergize the powerpack…  So, that is the circuit that must be interrupted with the safety switch.    See my comments below though…
                    #295933
                    Steven Lichty
                      Thanks, guys. I ended up interrupting the red power wire off of the back of the key switch in the box, and running that to the kill switch lanyard, and then back into the control box. When the kill switch is pulled, it opens the circuit, so that should do it. I haven’t tested it yet but will report back as soon as the weather improves around here and I’m suitably motivated to get the hose and muffs going! Thanks again.
                      #295949
                        OK, you shouldn’t interrupt the red power lead coming to the ignition switch.  The lead that should be interrupted is the purple lead on the accessory terminal of the key switch.  (not sure how many purple leads are on this terminal on your engine though).
                        Keep in mind that this engine has battery CD ignition and a hydro electric gearcase, so there is some current running through that key switch at all times when running.  You must be very careful to use a robust/water proof switch/wiring to avoid issues that might damage engine ignition and gearcase components.   There are some strange diodes in this system also.   Messing  with the wiring could actually cause a shorted “blocking diode” that would prevent the engine from shutting off when the key switch is turned off.  The shift diodes ensure the engine stays in neutral/doesn’t bang into forward gear, when the key switch is turned off.   Altering the wiring could cause poor connections and damage the ignition system “power pack” as well.
