Home › Forum › Ask A Member › How to reply on the webvertize page?
  • #3226
    dank
      I’ve put up an ad, had folks ask questions but it won’t let me respond to them. This board is different than the one I installed many years ago, but I’m not that out of it. 🙂
      #28926
        send a private message when all else fails.
        #28927
        beerman57
          Remember the old webvertize page – you couldn’t reply. There should be a box at top left and bottom left with "post reply".
          #28932
          AOMCI Webmaster
          Keymaster
            Dan
            You should be good now setting was off. Let me know all works.
            Travis
            Travis
            VP Communications AOMCI
            webmaster@aomci.org
            #28977
            dank
              Hmmm, still doesn’t show a Post Reply button.
              #28980
                The ‘Post Reply’ buttons at the top and bottom of your add are just for replying to your add. The way the system works, the only way to contact a replier is to click on their name or the contact button on the right hand side and send them a PM unless they have posted their contact info. This holds true for all sections on these boards.
                #28987
                dank
                  When I log out of the board, the Post Reply button appears, but when I click on Post Reply and attempt to log in, I get a "You cannot reply in this forum."
                  Do you mean to say "The ‘Post Reply’ buttons at the top and bottom of your add are just for others replying to your ad."? If so, that doesn’t seem to be the case for all the ads on the Webvertize, since I’ve seen other ads where the original poster has replied more than once.
                  #29033
                    Are you logging in first Dan? If so, you should be able to reply to any ad.
                    Using the reply buttons will also let you reply to your own ad.
                    #29044
                    dank
                      #29055
                        So ‘Post Reply’ buttons are not visible when you are logged in?
