Home › Forum › Ask A Member › How to remove paint safely…..
  • #6942
    opposedtwin
      Under all this extra paint there are a couple original alumacraft decals. Is there a safe way to remove the paint and preserve the decals? I’d like to take some good pictures so a decal maker can copy them.
        I would practise on an area without the decal. Start with a mild paint remover.
        Or Strip them and buy a decal pre made. It is likely one of these two?
        http://discontinueddecals.com/images/al … s_oval.jpg
        http://thumbs2.ebaystatic.com/d/l225/m/ … PzvHkg.jpg
        #57216
        opposedtwin
          it’s neither of those two. I will look in my pics to see if I have one similar.
          #57217
          mr-asa
            Lemme do some searching. I know I’ve covered this briefly before, I’ll see if I can find it again.
            #57218
            opposedtwin
              I think it will be like this one.
              opposedtwin
                Here’s another of mine after some gentle cleaner wax.
                oldboat1
                  I wonder if tape might lift off the paint and leave the decal. Maybe duct tape or one of the various painters or masking tapes. I know regular masking tape (the tan stuff) usually wants to lift off the paint underneath rather than peeling cleanly away — might be what would work for you.
                  #57227
                  Monte NZ
                    I have found that using very fine wet and dry sandpaper is effective.
                    Use the finest paper wet, a with a bit of detergent and sponge……do a small area at a time and finish of with cutter/polish…..
                    just take it quietly and check constantly.
                    MonteNZ
                    #57246
                    mas
                      What about a hair dryer to soften the paint then push off with your fingernail or wood stick?
                      Mas
                      #57271
                      opposedtwin
                        Some very good ideas guys! Thanks! I’ll try them and get back to you.
