Home › Forum › Ask A Member › How to measure poppet valve spring pressure
- This topic has 8 replies, 5 voices, and was last updated 11 years, 2 months ago by
eviltwin.
September 6, 2015 at 1:44 am #2461
How do you measure poppet valve spring pressure in regard to fuel systems? Is there a tool?
Thanks!
September 6, 2015 at 3:08 am #23316I used a postal scale, long gone. When needed, I borrow my sisters scale. She got it to measure portions in one of her weight loss diets. It says "Polder®" on the front and "not legal for trade" on the bottom.
September 6, 2015 at 3:49 am #23318If you have some fishing weights and a set of decent calipers, you could use Hooke’s Law to find the spring pressure
September 6, 2015 at 1:36 pm #23334Thanks for the replies.
Hmmmm. A little confusing to me. I see how to measure and adjust the height using a drill bit. The only way I can think of doing the pressure is with the poppet out put desired weight on it and see if it moves desired distance. To do that, I would have the spring and poppet assembly upside down and just place the weight on it and see if it moves the desired distance. But I would have to account for the weight of the poppet. Or should I rig up some method of blowing air against the poppet and a ‘seat’ made of tubing and somehow measure pressure. There must be a simple way that I am just not seeing. Maybe I will adjust the height and hope for the best with the pressure, unless the spring has been bent it would not have changed much, no?
Again, thanks for your replies.September 6, 2015 at 4:46 pm #23345A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 8 years ago by
Tubs.
Tubs.
September 6, 2015 at 8:27 pm #23371Wait a minute, I was looking at pics of it and had an epiphany. I see the brass base of the poppet that is used to prime it sticks out the bottom. I could press that against a small food scale without bottoming it out and get a reading, no? What confused me was I was thinking of a pull or hanging scale, not one that could be pressed against.
September 7, 2015 at 4:21 pm #23411I know that some of the members of the RBM chapters use pressure on scales to measure and perhaps they will share their methodology.
SkegSeptember 8, 2015 at 12:53 pm #23470
Tubs.
Tubs.
September 8, 2015 at 11:29 pm #23488Tubs! That is a really clear reply, Thanks! Hope you didn’t do the pics just for me. But it applies to many models and will help others I am sure. I will post back when I get it done, hopefully this weekend. Well done sir!
