Home › Forum › Ask A Member › How to identify a motor without markings?
Viewing 6 posts - 21 through 26 (of 26 total)
  • #43610
    superman1
      i really appreciate it Steve D that is some great info. i am printing them as we speak.
      now on the prowl to find a few parts so i can get this relic running.
      thanks again.
      #43619
      chinewalker
        Let me know what you need – I have most of a QD-16 parts motor in a box.
        #43624
        superman1
          quote Chinewalker:
          i’m not 100% sure what i may need to get it running? this is my first "antique" outboard motor.
          I can see it is missing the twist throttle grip. it connects to what i would call a throttle linkage, but it seems the more i dig into it, it may be called a drive shaft? the first one is there but the rod it connects to via the gear is missing. i’m also on the lookout for a pressurized two line gas tank.
          if you don’t mind could you private message me some more info about the parts box you have.
          thanks
          #43627
          David Stanton
            quote Superman1:
            Assuming this is in fact a 1955 QD-16, is this a good motor? There are a few things I know I need, but don’t really know where to get them.
            Such as, it looks to be missing a cable or rod that the twist throttle attaches to. And the twist handle.
            Thanks all
            It is a good motor. The only downside is if there are mega-hours on it, the wrist pin/piston rod interface is known to wear, and newer ones have better rods. Do not skimp on oil in the gas.
            For the parts you need, post a free "Wanted" ad on the aomci "classified" board (you don’t have to be a member to use it but I recommend joining anyway for the magazine). Tiller handles (your twist grip throttle) interchange across several HPs and years for your motor. I just put a tiller and the parts it mounts to on a 1958 10 HP Johnson QD-19 that came from a 1960 5 HP – looks a bit different but it works.
            I’m also sending you a PM.
            Steve D
              Here’s a couple more pages you can print out from the Owner’s Manual.
              photo sharing websites
              #43652
              raglover
                Hi superman1. Sent you s pm with my contact info to help link you up with the group in NC
