Home › Forum › Ask A Member › How to fix a dented tank?
  • #3041
    wyo307
      Hello everyone,
      I just received my 4378 zephyr via FedEx last night and somewhere along the way they had dropped it straight on the gas cap. This resulted in the area under the cap getting pushed in badly. Also closer to the edge of the tank is pushed in although it is less severe. Really ticks me off because the tank was perfect before this. I am filing a claim with fedex but that still doesn’t fix it so what do I do? What is everyone’s method for removing dents from a tank? I would rather not cut any holes in it if possible. Could I just fill it with water and throw it in the freezer? Also with this tank being internally vented do I have to worry about damaging that?
      Thank you in advance,
      Ryan
      #27606
      wyo307
          Here is how the factory said to fix them. Disclaimer: I’ve never tried it.
          posted image
          #27613
          PugetSoundBoater
            These instructions had better be followed carefully to the "T", a fuel vapor explosion could be fatal. I’m sure the company lawyers wouldn’t recommend this info to be released to customers.
            Robbie Robertson
            #27625
            cajuncook1
              I have used a slide hammer to lift and unsquash a gas tank’s neck. The motor was a 1937 johnson 1.7hp model 110. Yes the postal service had done a very bad job handling the package. You can file a grievance report with the local post master and get about $50 back. Don’t expect a fast return. I believe $50 can be filed for if it was not insured
              http://www.harborfreight.com/slide-hamm … 60554.html
              #27627
                What I do to pull dents, is weld "pins" onto the dent. I fill the tank with a small amount of air, just a few pounds. Lightly heat around dent, then I use a slide hammer like posted above, attached to the pin, to pop the dent out. Grind off the welded pin, then the tank can be polished.
                There are ways, to pressurize the tank, heat around the dent, and tap out with a hammer, but Im either too stupid, or dense to master that. For me, using the slide hammer on a welded pin works best, but everyone has their own way.
                #27628
                  Sorry your tank got damaged during shipping. I for one try to keep as much of the original parts on my motors as possible.
                  One of the thinks I consider is the rarity of the motor and parts availability, Zephyrs and their parts are plentiful.
                  Before spending hours trying to work out that dent and risking more damage to the tank or you, you maybe able to find a really nice replacement for 25 bucks or less.
                  Just another option to consider
                  Respectfully
                  #27629
                  gjonz
                    I use the method Frank shows from the manufacture…EXCEPT…I use dry ice or snow if I have any around and alternate by heating and tapping then cramming the cold stuff up against the crease or dent. This causes an almost immediate cooling and retraction by the metal and most dents will come out eventually.
                    However this method will ruin paint and decals…so you may have to do some cosmetic work afterward like filling with fiberglass jelly and sanding, prepping, priming and painting.
                    Yeah…yeah…I know a lot of work! But it’s a hobby! It’s supposed to be about learning new techniques. If you just want to run motors…hell with it…
                    Make a claim and then get her running and have fun! She’s a beaut and now have a little more history that is all too apparent.
                    Good luck!
                    Greg.
                    #27655
                    fastjohn
                      Wyo307 I have several Zephyr tanks. I sent you a private message, or you can click on my name and send me a message.
                      #27664
                      wyo307
                        I pm’d you back fastjohn.
