Home › Forum › Ask A Member › How to find part numbers for kits?
Viewing 10 posts - 11 through 20 (of 24 total)
  • #16952
    RICHARD A. WHITE
      Okies…here ya go, this makes it what I think is really easy…goto:
      http://www.marineengine.com
      Look to the bottom left of the page for the Sierra marine Button..Click it, you will then see this: Use the instructions to go directly to the applications page for carbs and or lower unit seal kits… You could go as far as to bookmark each under carb or l/u seal kits to find it even easier. Here is the photo of what you should see to goto page listing:
      classicomctools@gmail.com
      #16955
      wiscoboater
        The sierra kit like others have said does not come with the new float. One other issue I’ve had with the 18-7043 kit is the packing washers. They are a little big and leak like crazy for a week or two. After that they seem to swell up from fuel soaking into them and are OK. This could be normal I guess, I’ll let FrankR or Mumbles comment on that but it makes it hard to dial in the carb at first because the same fuel leak is also a vacuum leak when running.
        #16957
        RICHARD A. WHITE
          quote wannabe outboard guy:
          So get the OEM that does have the float 439071….
          Which leads me to wonder, do y’all change the float every rebuild?
          #16961
          wiscoboater
            No, I only change the float if the motor is 50 to 60 years old and is still sporting the original. Would that not be proper? I’m just asking. You have most likely rebuilt hundreds more carbs then I have.
            #16966
            RICHARD A. WHITE
              Actually no, I use what is there.. have found a couple that were in dire need of replacement.. most still floated properly so i put them back in service…
              I do work on them, just not as a side job, lets say I am picky what I work on…I already have enough irons in the fire….most just plain were plugged up and no fuel passed…after a serious cleaning, there were good to go.. and hundreds more??? LOL nope 🙂
              #16979
              wiscoboater
                So your thoughts on the packing washers Richard? Is leaking at first normal?
                #16980
                mr-asa
                  quote Mumbles:
                  I can send you a ’74 Johnson Parts Reference Guide PDF but I’ll need your email addy again. I couldn’t find carb kits listed in it but my ’80 Reference Guide does. I can always scan the page out of it and send it to.
                  My dealer supplies gearcase seal kits for the 9.9 – 15 horse motors but I’m not sure about any others.
                  Email sent.
                  #16981
                  mr-asa
                    And has anyone found a cheap source for them? I know it’s been mentioned before, but I don’t think so on this forum.
                    #16984
                    RICHARD A. WHITE
                      Honestly I buy them 50 at a time,the packing gland washers, and dig out the old and replace with new on every one I work on…and I cant ever remember even looking for a leak there, guess I just never thought it would leak with new ones in place. At first I would just add one or two to ensure a snug needle. I really am a rookie at this, I do make mistakes, and I can learn. Still thinking about the Kerosene idea. It would ensure a good seal from the get go, if it was inclined to leak… oh heck, I am tired and need a shower, good night guys…LOL
                      #16985
                      RICHARD A. WHITE
                        quote Mr. Asa:
                        Sierra has them, let me look tomorrow….
