Home › Forum › Ask A Member › How the hell??????
Viewing 10 posts - 1 through 10 (of 23 total)
  • #4467
    RICHARD A. WHITE
      How the hell do you get to that dam screw WITHOUT removing the rewind starter nightmare?
      See below pic. Look for steel pointy device, it is the carb mount screw
      Not liking engineers too much…LOL
      classicomctools@gmail.com
      #37935
      DAN ANDERSON
        Small punch & hammer. Been knocking the nut loose like that forever. Don’t like to take the rewind off the motor either. When you get through cleaning the carb just start the nut with a small flat blade screw driver with thick grease on the blade. Knock it back tight again.
        Dan in TN
        #37936
        fisherman6
          Hi Richard,
          You don’t… kind of. 😉 You have to take the rewind starter nightmare (I like that description) loose, but not off completely. Let me see if I can go get a pic for you. You can take the thing loose and gingerly lift it up and lean it over to allow access to that carb nut. Just be careful not to bump it enough to tip it over and send it to unwinding. Not too bad to do though.
          -Ben
          OldJohnnyRude on YouTube
          #37938
          RICHARD A. WHITE
            So anyone other than me see this as a fair and just reason to string up an engineer?
            #37939
            RICHARD A. WHITE
              Oh wait it just got better, got the carb off, thanks Dan , worked surprisingly well, but look at this pointer now!!!!
              Yup that is daylight, now do I fill it with something? This is not my motor….
              #37940
              DAN ANDERSON
                Just one of a thousand reasons, but this one was easy to get around compared to some! Save your energy for the tough ones.
                Dan in TN
                #37941
                DAN ANDERSON
                  What is that? Crack? Freeze damage? Time for a cleaning & JB Weld or your favorite adhesive.
                  Dan in TN
                  #37942
                  fisherman6
                    Richard,
                    You might like the punch method like Dan uses. I have tried that and it works but it’s a little clumsy for me. I prefer to do it this way. Do whichever works for you but I got the pics. And I’m with Dan, I DO NOT like to take the recoil off the motor. 😮
                    -Ben
                    #37943
                      Ill have to try the punch method. I always do like Fisherman 6 does, simply loosen the recoil and tilt it over for access to the nut.
                      #37944
                      RICHARD A. WHITE
                        Just touching that dang nightmare gives me the heeby jeebies..LOL
                        Time for some sealer on that crack…LOL
