Home › Forum › Ask A Member › How should I protect the bottom of a metal fuel tank?
- This topic has 9 replies, 10 voices, and was last updated 7 years, 5 months ago by
David Stanton.
June 4, 2019 at 8:41 pm #176646
Well I found a great 3 gal fuel tank
How to you guys protect the bottom. Split a hose and glue?
<br />why fallout new vegas is better than 3<br />June 4, 2019 at 9:31 pm #176649I set mine on a piece of indoor-outdoor carpet. Not so much to protect the tank, but to keep it from rubbing around on the aluminum boat bottom.
June 4, 2019 at 9:36 pm #176650Anonymous
Ebay listing #360811548121 for metal fuel tanks. Very nice price.
June 5, 2019 at 9:16 am #176656I use the thick foam pads that you kneel on when gardening. They are about 1 1/2″ thick . Helps absorb noise as well when you hit waves.
Bob DJune 5, 2019 at 11:11 am #176665I was researching this topic last night… great minds think alike. I have some existing tanks that have white trim and I’d like to match that.
I haven’t confirmed the dimensions yet but I did find this on amazon:
https://www.amazon.com/White-small-0-375-height-0-093/dp/B00KI2CCSSThere are other similar items. “Edge trim” or “edge guard” is the item to be searching for. If anyone has a specific recommendation for trim in white – please post.
This reply was modified 7 years, 5 months ago by
h20lew.
June 5, 2019 at 2:04 pm #176673I use old floor mats from a car. I also never let tank set on the ground very long. All my cans are stored inside on a raised platform and covered with an old rug. Condensation from weather change will mess your gas can up inside real quick.
dale
June 5, 2019 at 4:25 pm #176679I use a split rubber hose. No need to use glue.
June 10, 2019 at 3:58 pm #177067Boat places used to sell the white edge trim stuff for putting around tank bottom seams. I have used it but think it may trap water and contribute to deterioration of the tank.
June 10, 2019 at 5:42 pm #177075I use a rubber door mat about 1/2″ thick found at local discount store. Same approach as F.Robb. Works well to protect the boat and the tank. Simple and good.
June 11, 2019 at 12:28 pm #177141I have used use small rubber-backed rugs with a low pile so easy to keep clean. These are often advertised as rugs that will not slip on a smooth floor. I cut them down to a couple inches larger than the tank on all sides.
Dave -
