Home › Forum › Ask A Member › How many amps for a 6V battery?
  • #5122
    mr-asa
      Trying to get my stuff together for my Herter’s, I want to tear into the ’55 25HP Evinrude next. Plan is to go through the foot, the carburetor, inspect the ignition, then try to crank it.
      I don’t particularly want to try and pull over the motor by hand, so I was going to start it. To do so I need to get the wiring and power straightened out.
      I’m mildly concerned with weight as I don’t want to have to lug everything around everywhere. Can I get a couple of 6v dry cell batteries and wire them in parallel? Is there a more reliable method?
      What does everyone else use when they have a motor with a starter?
      #43011
        I’ve never tried Dry Cells, but I seriously doubt they will work.
        #43013
          I like a real battery but some guys at work will do a quick test with one of those jump packs, because they ARE lighter than a real battery.
          #43014
          RICHARD A. WHITE
            Think 12 volt Motorcycle or ATV battery, will easily crank that one over…
            classicomctools@gmail.com
            #43017
            mercuryman
              In 1957 Gale recommended a 6 volt 100 amp hr. battery or for 12 volt 60 amp hr.
              #43037
              mr-asa
                quote Richard A. White:
                A 12v won’t fry anything?
                #43039
                David Stanton
                  The dry cells won’t work – you will just damage the batteries, but 6 Volt starters work fine on 12 volts and give much faster starts, so the small motorcycle 12s mentioned by others will work, the question is how many starts do you want on a charge? and how long do you want to crank if it doesn’t start right away? like if it gets flooded? Don’t go too small. If you go to 12 volts, I recommend a resistor in series with the choke actuator to drop it to 6 volts, because if it’s held on too long with 12 volts, it will get hot and may self-destruct. The resistor should be the same Resistance as the choke actuator coil, and have a high enough power rating (Minimum Power in watts = 36/R) For a lighter, smaller, battery at a good price, I recommend the 12 Volt garden tractor batteries – Menards often has them on sale.
                  Note that due to the inductive nature of the starter motor, it will not draw fully twice the current at 12 volts that it does at 6 volts – Ohms law does not apply directly here. Old 6 volt cars are commonly converted to 12 volts without changing the starter.
                  Tom
                    I ran my 6V Johnson on a 12V battery for a couple of seasons. it was one of those smaller tractor batteries, as suggested above. Just make sure the motor is in good shape and runs well. If you have to crank it for more than a couple of seconds at a time, there’s something that should be fixed. I only flipped the choke quickly, so I don’t know how long it would last with constant use. I usually just used the manual choke because the configuration of my boat put me pretty close to the motor.
                    T
                    #43062
                    RICHARD A. WHITE
                      I ran my 1955 Evinrude 25 hp on our pontoon. Charged a 12 volt car battery once. Stored indoors for the winter, northern Indiana here so you understand why indoors. Ran a minimum for 60 gallons of fuel in those 3 years. We would take rides up to 4 times per week, depending on the weather. Only used for starting, never charged it over that 3 year period…. Even used that battery on my truck to jump it when its battery died. Yes I had a 12 volt solenoid, and yes it was a 6 volt starter. But as previously stated, get it timed right and tuned right and the battery will last for a very long time…
                      #43072
                        Use a 12 volt battery as mentioned. Either….
                        a) wire In a resistor
                        or….
                        b) change out the starter solenoid and choke solenoid to one from a say ’57 35hp, which is 12 volt.
                        The following diagram will help.
