Home › Forum › Ask A Member › How long will it take…
  • #4454
    blackwater
      Info here suggests that today’s gas will/can be absorbed into a cork carb float. I assume that this doesn’t happen overnight. Can I guess that I’d be safe if I make sure that the bowl is empty when the motor is stored? To coat the float, I hate to mess with the float keepers/clips to get the float out to coat it.
      Thank you.
      #37831
        Sent you a PM
        Check your messages at
        the top right of this page.
