Home › Forum › Ask A Member › How do "you" ID props?
  • #4801
      I’ve been going through a box of props that I don’t need, nor
      never knew what they originally were on, that I want
      to get rid of at Tomahawk.
      I’ve wrote down all the numbers I could find, noted rotation,
      shaft size, # of splines, etc..
      I then proceeded to do Internet searches on each. In some
      cases I’d find additional information about diameter and pitch,
      but rarely "exactly" what they fit.
      For one OMC prop I found info that it fit various motors from
      a 1968 55 hp, to a 1984 90 hp. Is that even possible?
      What’s the best way to ID props as to what they "fit"?
      Below is what I came up with so far for an idea of what
      I’m up against. I’m not asking anyone to try to ID each prop
      for me, just wondering "how" I can do better. The shaft diameters
      were measure in the back side of the prop bores, as some of
      them had splines on the front side.
      Thanks, Buccanneer
      Props
      1. 3 blade, RH, (MichiganPR 82) 072034, 13-1/8 x 19, 1" shaft
      2. 3 blade, RH, (OMC 382764) (13-1/4 x 17) 1.065 shaft. 13 spline,
      50 – 140 hp, (needs prop shop)
      3. 3 blade, RH, (P495) .882 shaft, 13 spline
      4. 3 blade, RH, (Michigan PR552) 10 x 12, .882 shaft, Chrysler
      5. 3 blade, RH, (T 9.75 x 9.5 P) (48-896892A40) .712 shaft, Mercury
      6. 2 blade, RH (48-56238-12) .882 shaft, 11 x 12, Mercury
      7. 3 blade, RH, (Michigan PJ 90 cup) 1.065 shaft, (OMC 391199)
      13.25 x 17, 13 spline
      8. _ blade, H, (382763) 13-3/4 x 15, ______ shaft
      OMC 1968 to 1984, i.e, 1968 Evinrude 55hp, 1984 Evinrude 90hp
      9. 3 blade, RH, (293265), Force 50 hp?, 10 x 12, 14 spline
      10. 3 blade, RH, 40 hp, .805 shaft, no splines
      11. 3 blade, RH, (OMC 307431) 10 x 12
      12. 3 blade, RH, (Michigan 072014) 10-3/8 x 10 (Force / Chrysler?) 14 spline
      13. 3 blade, RH, OMC?, shaft size .790, Brass hub stamped "D"
      14. 3 blade, RH, small, hub b.o.
      15. 3 blade, RH, (BWA 5265) Chrysler, 10-1/2 x 15
      16. 3 blade, RH, (Suzuki 30840) small, 190 x 150
      chinewalker
        As to one of your initial questions, yes, the 1968 55 hp 3-cylinder OMC propeller will also fit up into the 1990s V4 models. Johnson and Evinrude 3-cylinder and crossflow V4s used the same propshaft spline configuration for a generation and then some. Might still use it…
        #40577
          Thanks Chinewalker, with all those applications I should at
          least be able to get rid of that prop!
          Was just told that a 13 spline prop is likely for an OMC.
          Great tip!
