Home › Forum › Ask A Member › Honda Powered Lightwin
- This topic has 13 replies, 10 voices, and was last updated 4 years, 11 months ago by
JACQUES.
December 5, 2021 at 2:00 pm #250720December 6, 2021 at 5:41 am #250742
I’m trying to understand what’s going on at the hybrid joint. There seems to be some kind of covering over the area of connection between the mower engine and the Lightwin base gasket area. It actually looks kind of professional but I can’t tell what the guy used to do it. He could have at least used a whole lower unit, though….Also, did he actually install what looks like a Japanese outboard’s stop switch on the engine cowl or is that standard lawnmower?
This reply was modified 4 years, 11 months ago by
billw.
December 6, 2021 at 10:19 am #250748I wonder if there are other images shot from other angles?
It does look way better than the typical lawnmower on a stick.
Even the lower unit seems to look a bit different. Might just be the angle the picture was shot from
Not sure what’s going on with the speed control. Looks like the cable from the Honda loops past the tiller control. And the engine side of the loop appears to be a thicker cable???
December 6, 2021 at 5:10 pm #250762I’ve seen some Lightwin lower units that pretty much break off that way….
December 6, 2021 at 5:46 pm #250763I’ve seen some Lightwin lower units that pretty much break off that way….
Yeah, the extension piece on the exhaust snout often gets broken off.
December 6, 2021 at 8:28 pm #250767Doesn’t everyone have one of those old mixed up thingies? Here is my Water Boy, I have not gotten it to run so good yet. I am ready to tear it apart and scrap it. It kept me busy a couple winters ago. I made it from a 14hp Evinrude leg. Don’t laugh to hard!
dale
if your gonna do it wrong! do it right!
Water Boy!
December 6, 2021 at 10:56 pm #250773I have my grandfather’s old push mower. It hasn’t run in over
40 years…….. maybe I better get busy and make on of those!Prepare to be boarded!
December 7, 2021 at 2:27 am #250774That old Lawn Boy is only around 1.75hp it still is pretty cool looking.
December 7, 2021 at 11:33 pm #250827As many of those motors there are around, I would never make myself listen to the noise of a lawn mower while going fishing.
December 8, 2021 at 5:36 am #250828On the other hand, one of the good things about a Lawnboy lawn mower is that it smells both like fresh cut grass AND being out in your boat….So a Lawnboy outboard is smell-redundant! A few thoughts about the one pictured in this thread: Like has been said, the horse power is low. If you’re trying to drive a 14 hp prop, that may be problem #1. Problem #2 is more subtle….Remember that on a lawn mower, the blade acts as part of the over-all flywheel effect. I will never forget as a kid, trying to run a vertical shaft, Briggs and Stratton, without a blade. It would barely even start or run, until I put the blade back on. Then it was fine.
billw.
