Home › Forum › Ask A Member › Homelite
  • #3834
    gdcarpenter
      1964 55 HP Homelite "4 Cycle"
      I might have some interest in this engine, but know nothing about them, any basic info?
      It’s a nit, but I see all engines, be they 2 stroke or 4 stroke, as being "4 Cycle" engines.
      They still do the suck/squeeze/bang/blow thing, but, since areas both above and below the piston are working in a 2 stroke, it has 2X the power stokes for 2 CS rev’s than a 4 stroke
      Anyway, Homelite:
      Difficulty to work on, I was an auto mechanic in a former life so 4 stroke not an issue
      Availability of parts and resources
      Desirability
      Uniqueness
      Thanks
      #33372
        Not too difficult to work on–unless it needs a valve job. That requires total engine teardown, because it is an overhead valve/overhead cam with no cylinder head. I suppose you probably have already found out it is a Crosley engine standing on end. Exhaust manifolds rotted out in salt water. Don’t know about fresh water. Of course, it is a cast iron block, which survived the salt fairly well, which is amazing.
        Availability of parts?? I don’t know, haven’t tried to get any for many moons now.
        Desirability/Uniqueness?? Certainly unique. You will have to decide the desirability. Personally, I’ll let you have it.
        #33426
        John
          all of what Frank said – – – when I was in Key West back in the ’70s, I had 4 of them.
          the simple parts were available at the auto parts store.
          Looking back, I wish I had kept at least two of them for now.
          I don’t know the weight vs the aluminum Big Twins, but is probably a lot more.
          #33433
          SCOTT BOGUE
            Search "Homelite Outboard," "Bearcat outboard," "Fisher-Price outboard," "Fageol Outboard." Several of the club members have ’em. There was also a 90 hp that was based (I think) on a Coventry-Climax engine.
            #33442
            RICK EICHRODT
              Here are a couple of pictures of my 1970 Bearcat 55.
                No cylinder head with overhead cam and valves? Why do I think Carl Kiekhaefer must have had something to do with that? Lol.
                #261739
                Rodrigo65
                  First time boat owner I recently picked up a 1964 homelite on a 1964 sea king. Motor is untouched, no key , So I replaced ignition and did a full tune up. She fired right up but no water coming out. I heard people talking about check thermostat, visually I could not locate? Any ideas?
                  • This reply was modified 4 years, 4 months ago by Rodrigo65.
                  #261743
                    It’s been fourty forevers since I’ve seen one, but isn’t that black item on the backside of the exhaust elbow a thermostat housing?  Whether or not, it certainly needs a new water pump impeller after all these years.
                    #261820
                    bkrsdoz
                      The Homelites were variants of the defunct Crosley Automobile company engines. Crosley 4 cylinder cars/engines were made from 1946-1952. Then a variety of companies used the engine for many applications. Homelite Bearcat, Fisher Outboards, Fageol & Elgin inboard units, ThermoKing refrigeration units, and a few small production car companies put them to use. More info can be seen on the Crosley Automobile Club website.
                      #261834
                      outboardnut
                        My buddy in Gaylord Mi. would sell his Bearcat.
                        Comes with non functional boat and non functional trailer
                        I think he want $250 for everything
                        Contact me if you want his info
                        received_408666407762523
                        received_937079566988032
                        received_1033339294206773
