Home › Forum › Ask A Member › hinge pin ’57 35 hp Johnson
  • #8384
    jiall2
      Can anyone tell me if the hinge pin on a 57 Johnson 35 hp (P/N is 303984)is straight or tapered? I would like to drive it out to separate the cowling. Thanks for any help
      #65710
        I believe it is straight. The hole may be tapered. Heating will help. . .
        #65719
        DAN ANDERSON
          As Garry says heating will help, but the pin is splined on one end. Check out this reference pic off Ebay. (For reference only. Not the actual pin number.)
          http://www.ebay.com/itm/Vintage-OMC-Joh … qu&vxp=mtr
          Hope that helps!
          Dan in TN
