Home › Forum › Ask A Member › High Speed Needle – O-Rings/ Washers
- This topic has 6 replies, 5 voices, and was last updated 2 years, 3 months ago by
John Gragg.
July 1, 2024 at 6:34 pm #288775
1956 Johnson QD-17 10hp.
Im looking for the seals/ o-rings for the high speed needle valve .
I have fuel leaking out around the brass barrel. What comes in the carb kit does not fit.
Would anyone happen to have any info or part #s on these seals ? I can only look at a schematic of a 1958 on Marine Engine.
Thank you , As always appreciate the help !
July 1, 2024 at 11:15 pm #288788if you can’t find the parts stuff it with wraps of dental floss or similar greased fiber
the kit should fit did you screw down the brass barrel tight..
vintage outboard.com has kits Sierra 18-7043 for 2-20hp
18-7043 – Johnson/Evinrude Carburetor Kit (OE or Sierra Kits (shipped – VintageOutboard.com
July 2, 2024 at 8:07 pm #288806Yes , Thank you for the info. I think ive got it now.
July 12, 2024 at 10:26 pm #289108I too have had some problems with those fibre packing washers. I bought a cheap generic carb kit on Amazon that came with float and a bunch of unidentifiable stuff for most motors up to 18 hp. The washers would not fit either jet. The float had to be modified to fit. The brass float needle thing had the wrong thread (probably metric). Now this kit cost $15.00. each. So I sent them back and ordered better kits for a total of $10 more. When it finally arrived, late, I discovered they were exactly the same kits but from a different supplier. Not sure the washers fit either. So I ordered just the packing washers from Sierra directly. Ten in a pack alone cost me $15.00 and they are identical to the ones included in the offshore kit.
It seems that carb kits have gone the same way as the points kits. Useless.
July 13, 2024 at 8:17 am #289111did you try or talk to vintage outboard about this problem … they know their stuff and I hardly think they would ship kits that dont fit.
July 14, 2024 at 9:07 pm #289150I too have had some problems with those fibre packing washers. I bought a cheap generic carb kit on Amazon that came with float and a bunch of unidentifiable stuff for most motors up to 18 hp. The washers would not fit either jet. The float had to be modified to fit. The brass float needle thing had the wrong thread (probably metric). Now this kit cost $15.00. each. So I sent them back and ordered better kits for a total of $10 more. When it finally arrived, late, I discovered they were exactly the same kits but from a different supplier. Not sure the washers fit either. So I ordered just the packing washers from Sierra directly. Ten in a pack alone cost me $15.00 and they are identical to the ones included in the offshore kit.
So far I think the Genuine OMC carb kits re OK. All the right components and good quality.
Marine Engine lists them all here:
https://www.marineengine.com/parts/brp/johnson-evinrude-outboard/carburetor-kit.html
You can observe their pricing for the genuine kits and if someone is selling you something for a lot less……it’s probably not going to be what you need and want.
July 15, 2024 at 2:19 am #289171I’m 99% sure you are looking for part# 307583. These are the packing washers only and should be a part of carb kit 439071. I’m only assuming your motor uses this kit as it is a 10HP and other years in that bracket use that same kit.
If u have the kit you use the washers as replacements for the existing packing washers and the plastic (almost clear) washer as the support/packer for the other washers.
So, fiber, fiber, fiber, plastic would be the order the washers would enter the needle bore.
Hope I’m helping, if not please ignore.
Best Regards
John Gragg
RIverside, CAJust starting in the hobby, please be patient.
48 Sea King 5hp GG9014A. Sold
49 Sea King 5hp GG9014A
48 Johnson TD20. Sold
49 Johnson TD20. Sold
54 Johnson QD15. Sold
55 Johnson CD12. Sold
57 Johnson RJE-19M
57 Johnson RDE-19 -
