Home › Forum › Ask A Member › Here’s one like I’m looking for. Johnson 10 hp
  • #5768
    paulfromyork
      http://www.ebay.com/itm/Antique-Vintage … 3197642725
      This one has the 5 bolt lower. I wonder what else could be wrong with it?
      #47996
        You have to expect a worse case scenario with any old motor. The splines on the crank and driveshaft can rust and wear and replacing the ignition system, coils, points etc., water pump, carb kit and resealing the gearcase can be expected as basic to do chores unless the seller can show it running and has receipts for recent maintenance work. These motors are getting old and not all of them get the care they need.
        #47999
          It has been run hot. At least he did replace the head gasket and exhaust cover gaskets after it happened. Anybody’s guess as to how much other heat damage happened.
          #48001
            well it turned all black so must be pretty bad 😆
            I worry about any repaint from a guy who can’t event try to do some.. paint
            matching 🙁
            anything above $75-100 is to much for me for an oldy
            #48002
            paulfromyork
              How can you tell it’s been run hot?
              #48003
              vintin
                quote paulfromYork:
                Following up on what FrankR mentioned:
                Notice the color change in the paint on the head. That’s a sure sign it’s been run hot. Damaged? Maybe and maybe not but a good chance it has.
                #48007
                  Well, it is certainly worth a look if not far away…Yeah, it’s been run hot, but these engines are pretty rugged and tolerate a lot of abuse. To me, it kind of looks like the head gasket was replaced, so that is good. Seller reports the compression to be OK, but you would have to confirm this…You will want to inspect the gear lube as well.
                  But, the seller wants way too much money, so don’t bother unless he is willing to negotiate. Too bad about the black paint as well.
                  #48009
                    In my opinion, it’s worth $85 tops, at a local aomci meet here in FL. But then I’m a cheap bugger.
                    #48021
                    paulfromyork
                      Right there with ya’ on the "cheap bugger". That’s one reason (of many) I like this group. You all get your $$$’s worth, and then some. Sorta’ like takin your Dad and his car freak friend when you buy your first car. It’s just the smart thing to do.
                      #48080
                        I’m getting cheaper with age as well….Someone killed this engine’s possible value just by painting it black, worth much more in its original paint. Don’t get me wrong, if this engine was in nice cosmetic and mechanical shape, I would be willing to pay this price and perhaps more. I love the 55 Johnson color and graphics. I would call the seller to see if his price is negotiable, if so, I would go look at it. I agree, that engine looks more like a $100 old used outboard to me. On the plus side, the engine likes to be whole, and hasn’t been badly molested.
                        Negotiations will be tricky, the seller is likely to be offended if you just spring the $100 offer in him. Give him some time to see if his ebay offer pans out, then gently explain all the various service operations that will be needed to make this a reliable daily runner…Finding a decent fuel tank will cost money as well…
                        PS-Don’t forget to point out the engine has been badly overheated at some point, and there may be hidden piston/cylinder damage/wear.
