Home › Forum › Ask A Member › Help with prop identification.
  • #3181
    david-bartlett
      I have a bronze prop that was on my 1948 SpeediTwin. It is a Michigan prop, it has the letters AM, then some illegible numbers, then the number 219P. 3 blades. Shaft size is roughly 1", and the hub length is approx. 1-7/8". Diameter approx 9-3/4".
      Taking any and all guesses. Thanks.
      #28720
        Dave could you post pictures of the prop at different angles? It may be a AM162 @11p or AM163 @10p
        #28736
        david-bartlett
          XR55,
          Here are some pictures. .com/albums/e1/dbartlett1958/PC170230_zpsuzwod3yy.jpg[/IMG][/URL]
          Open to any and all suggestions. Thanks
          #28759
            #28771
            retiredoz
              Closest I get is AM 220 ( I think this is AM 219) for Johnson SD. 9 1/2 x 11, light boats and loads..Seems odd that the wear would be limited to where the illegible serial number would go ?
              #28880
              TOM GOEPFRICH
                With a 1" bore and 9 3/4" dia I’d say it is for a ’46 to ’50 Speeditwin or Speedifour. Maybe an AM163.
                #28903
                david-bartlett
                  quote eltoquad:
                  With a 1″ bore and 9 3/4″ dia I’d say it is for a ’46 to ’50 Speeditwin or Speedifour. Maybe an AM163.
                  Well it was on the SpeediTwin when I got it so if I get it running I will see how it goes.
                  Thanks.
