Home › Forum › Ask A Member › Help With Measurements of Two Chrysler Impellers
  • #3381
    lotec
      I am working on project and looking for a suitable impeller. It is possible two "newer" Chrysler/Force impellers may fit, I’m trying to verify the dimensions before I plunk down the money to buy them. If someone had one of these handy, (either new or used), and could provide the measurements, it would be a huge help.
      #1) Chrysler P/N 84065, Mercury # 47-F84065 or Sierra # 18-3085 – this fits the 55hp to 140hp motors from 1961 to the mid 1970s
      #2) Chrysler P/N 474065-1, Mercury # 47-F474065-1 (no Sierra # I could find) – this should fit the mid 1970s to about 1985 55hp & 60hp
      Here is a diagram with examples of the three dimensions I need: (Note: dimensions given are just for example!)
      Thanks in advance for any help!
      #30083
      mercuryman
        18-3085 OD 2.225 From Chart made by Chesapeake chapter AOMCI
        Bore .815
        Height .790
        Blades 12
        Key 0.130 ( must be size of slot in hub)
        #30087
        lotec
          Thanks Mercuryman – I have that chart Mike Bowles did but the measurements on several are suspect, why I was hoping to get someone to confirm with an actual example.
