Home › Forum › Ask A Member › Help with Electrical Specs 1996 Johnson 15HP 4-Stroke
  • #4210
    CHUCK
      Can someone help get me the electrical specs (ohms and DVA Volts) and testing procedures for the Stator, Coil, and Powerpack for a Johnson J15FRLEDR; 1996 4-Stroke 15 HP.
      The Stator PN#0584614
      The Coil PN#0584451
      The Powerpack PN#0586136 / 0586505 / 0586650
      I have a no-spark condition.
      Thanks; I appreciate it.
      Chuck
      #36027
        Will look to see if I have a 4 stroke manual when I get home. For now, have you disconnected the stop switch and checked the pack ground??
        #36056
        CHUCK
          Yes Fleetwin….I have cleaned up all the connections (grounds) and disconnected the stop switch. No go.
          #36108
            Sorry, don’t have a four stroke manual…
            The coil is a strange dual fire coil, meaning it fires both cylinders at the same time producing "waste spark" on the cylinder that is not on its compression stroke. So, to measure the secondary resistance you would measure between the two plug lead towers. I’m "guessing" the secondary resistance is similar to standard OMC coils of the day at several hundred ohms. Because this is a dual fire coil, there is only one primary circuit, and it is checked like a conventional OMC coil, between ground/strap and the primary tower, it will probably read less than one ohm.
            Hopefully someone else has the manual and can post sensor and charge coil resistance readings, do you have a meter capable of reading peak voltage? If so, you could check the output of these components as well…
            Hopefully the pack is OK, these are getting expensive and hard to find….Don’t know if the various independent suppliers can rebuild these parts…
            Saw a few of these on ebay, very pricey, a few offered by CDI….Maybe they will discount slightly for a core return….
            Hope it is something simple
            http://www.ebay.com/sch/i.html?_from=R4 … 6&_sacat=0
            I think these flywheels have an "encoder ring" underneath that is read by the pack, might be worth removing the flywheel to make sure this is not broken.
