Home › Forum › Ask A Member › Help with Anzani Minor
  • #5191
    Tom
      Can anyone tell me how to separate the water tube from the water pump housing on an Anzani Minor? The water tube goes through the anti-cav plate, and I cannot open up the lower unit without taking the water tube out of the rear housing.
      Thanks,
      Tom
      #43554
      collectorinspector
        GDay Tom
        The water tube is a sliding fit through the cav plate and is a sliding fit into the water pump housing below that.
        I suggest soaking and heating as required to loosen corrosion that is sticking everything together.
        It may take some time so be gentle.
        I will post pics if you need them.
        Cheers
        BnC
        #43577
        Tom
          BnC, that’s exactly what I needed to know. I’ll give that a shot.
          Thanks,
          Tom
