Home › Forum › Ask A Member › Help johnson A 1922
  • #2316
    sbrown21
      I just bought a Johnson A 1581 serial number , I bought it for $40.00 but it was locked up. I spent a couple of days on her before she broke loose. I have a couple of questions 1. did they have a grease zert on the lower unit? 2. It has a cast alum. gas tank but has a old decal that doesn’t look right it’s marked Johnson Seahorse 3 ? Final question does the prop come off like the newer units with the shear behind the prop or is mine just in need of a little pressure ? Thank you I can’t find any pictures .
      #22424
      Doug Wilson
        I am not sure on the ones from the 20s but the A-50 and K-50 both early 30’s have a shear pin in them.
        Doug
        turned off?
        #22426
          #22430
          sbrown21
            Thank you guys for the info , someone put a grease zerk on this motor I will have to find a screw to bring it back to original and the magneto reads higher than any one I have ever tested ( 30 on the 1k scale ) so I hope that’s good or back to the hunt for one of those.
            #22433
            JOHN D.
              Did you check the resistance at the coil or across the spark plug leads. There are several places in the circuit that could have resistance.
              #22436
              Goman
                Nice find. Try to post some pictures. A lot on here can dissect it pretty good for you.
                #22438
                  Sent you a PM.
                  Check your messages
                  at the top of the page.
