Home › Forum › Ask A Member › Help in identifying a Water Witch
  • #7232
    drifter
      I have a single cylinder Water Witch with the only identifying marks (that I could find) of S-214. This is stamped on the right side of cylinder – looking from the rear. The numbers 214 are also stamped on the flywheel. It is a twin tank (torpedo tanks) model and in really nice original shape. Only one small ding in one tank. I have not even attempted to clean it up because I like the look of the old dinge.
      Can someone help me with a model year? Is this a Kissel manufactured engine?
      Thanks,
      Drifter
      #58994
      JOHN D.
        I don’t find an s214 model. Could there be a stamping on the crankcase starboard side? My thoughts are a 1936_7 year motor. Is this a water or air cooled motor?
        #58996
        david-bartlett
          Drifter,
          If it has the twin tank set up it is a Kissel built motor. I have 2. One has the rope sheave held on by 3 screws and one is held on with the crankshaft nut. The 3 hole style is earlier, starting probably in 1938. Later style is around 1940.
          Hope this helps.
          #58997
            That would be the serial number.
            There is nothing on the rope sheave?
            #59056
            drifter
              Here are a couple of photos of the flywheel and the stamped numbers on the left side of the block looking from the front.
              There is no model number, appears to be only a s/n. These are the only numbers I can find. Is there a spot I’m overlooking?
              Thanks for the help,
              Drifter
              #59067
                Ok I’m going to speculate here.
                The original rope sheave got
                broken and that is a replacement.
                It came blank and someone
                stamped it with the motors serial #
                that’s on the block.
                Your tiller was first used in 1937.
                1936 is different. With that low
                a number I would speculate it to be
                a 1937 Model 571-10 and it should
                have this exhaust. Everything is the
                same in 1938. The model # and exhaust
                changes in 1939.
