Home › Forum › Ask A Member › Help identifying this old Sears Motor
- This topic has 5 replies, 2 voices, and was last updated 6 years, 10 months ago by
Bob Wight.
December 19, 2019 at 3:55 pm #189619
Greetings. I picked up this 2 cylinder engine yesterday. Owner said it is from the 40’s or 50’s. I have given a link with some pictures and any model /serial numbers I can find. I am thinking Elgin.
Since i want to get this running again I would appreciate knowing year/ model/ etc. The link is
https://drive.google.com/drive/folders/1PkKA0Df7LFTDhSU_t3xr8R_Fw-YJQFQH?usp=sharing
The coils seem to be newer rubber and not all cracked.
Question: one of the Carb bolts is snapped off. Is that a stud that I can back out of the base plate? If not what would you do to fix it? I guess I would need a welder for christmas to extend the bolt.
Thanks Ralph
December 19, 2019 at 4:12 pm #189620If I’m reading the first 3 digits of the ID number correctly, that would be a model 571.58601 which would be a 1947 model 5.5hp motor. The 3 digits of the motor ID number make up the last 3 digits of the model number. Here’s a link to Elgin model numbers.
http://www.elginoutboards.org/modelnumber-sequential.htm
You should be able to back the broken carburetor stud out once you remove the carb.
This reply was modified 6 years, 10 months ago by
Bob Wight.
December 19, 2019 at 5:19 pm #189623Bob.Thanks. Please check the link it is not working for me.
Also please let me know what number you based it on and the location on the motor so i can learn where the model is. and I will check.
thanks
RalphDecember 19, 2019 at 5:37 pm #189626Ralph – in one of your pictures there is a number 601-7165 which is the motor ID number. The 601 represents the last 3 digits of the Elgin model number 571.58601 and the 7165 is the serial number of your motor. See if this link works – it is a listing of Elgin model numbers.
http://elginoutboard.com/technical-data/elgin-ob-motor-model-data/
"Every time you remove a broken or seized bolt an angel gets his wings."January 4, 2020 at 8:24 pm #189624Ralph – in one of your pictures, there is a number 601-7165. The 601 digits are the last 3 numbers of the Elgin model number 571.58601 and the serial number of your motor is the 7165. See if this link works – it gives the listing of Elgin models:
https://web.archive.org/web/20160417045813/http://www.elginoutboards.org/modelnumber-sequential.htm
"Every time you remove a broken or seized bolt an angel gets his wings."January 4, 2020 at 8:24 pm #189625Ralph,
In one of your pictures, there is a number #601-7165 which is the motor ID number. The 601 digits represent the last 3 numbers of the Elgin model number 571.58601 and the 7165 is the serial number of your motor. See if this link works – it gives a listing of Elgin models:https://web.archive.org/web/20160417045813/http://www.elginoutboards.org/modelnumber-sequential.htm
"Every time you remove a broken or seized bolt an angel gets his wings." -
